I have a FX-8350 and my motherboard is an ASUS M5A78L-M/USB3 with a Corsair CX600 and I want do an overckock, so can i do ? And if i'll can what speed can i get with it ? thanks.
Google can work wonders. But just an observation, if you are this unfamiliar with overclocking you might want to give yourself some time to fully understand what is involved rather than just attempting it. I can only see this ending badly.
I'd say you'd probably be able to hit around 4.4 to 4.6Ghz
Anything more you're probably going to get throttling.
Most 8350s can do an extra 400 - 600Mhz with little to no voltage increase but of course you'll be at the grace of the silicone gods!
Remember that 1.55v is the max recommended voltage for this processor, and 62c is the Max Core temperature and it is advised that 70c is a soft limit for the socket (Depends on motherboard quality)
