Just wondering what you guys would recommend when it comes to running Furmark. I tend to run it for around 8 hours (as I sleep) afterwards check the temps and stare at the screen for 5 minutes to check for artifacts. Do you guys think I should go longer or is this overkill? AA is turn onto 4x, max res and post FX, displacement mapping and xtreme burn enabled.
