Full Ashampoo Burning Studio Free 4 Hours Left To Get It.
Damien c
Active member
http://giveaway.downloadcrew.com/offer/ashampoo_burning_studio/27200
Full Ashampoo Burning Studio Free.
Only 4 hours left before it goes paid for again.
Download it from the link above and install it, it will then ask you for a key and all you do is click "Get Free Activation" and it will take you to the site to get it.
You will get 1 email to confirm you email address, and once you click the link in it you will have your key displayed on the screen.
Once you have put the key in choose the custom install option if you don't want the toolbar installing.
Then click continue and your all done.
You will then recieve 2 more email's.
1 will contain your temp password for the Myashampoo section where you can turn off the annoying update emails etc.
The 2nd will contain you key.
Enjoy it as they are turning off the option to get it for free in 4 hours!!!
Thanks a lot
Thanks m8!
Why is it free do you know please?
Companies do things like this to attract more people. I know it's legit as Ashampoo have been around for ages. I recall using their software in 2003, and that was on an official PC Mag disc. Plus it's on the official website, so can be trusted
I have it installed and working now
Cheers m8; I guess it was a trustworthiness question!
Nice find mate, downloading it with 5 mins to spare, cuttin it close
One question, getting a SSD tomorrow so if i use my key again once WIN 7 is installed, will it work?
@Dipzy
It should work with no problems as it's basically the same as buying it from there site.
@Everyone
I found this posted on a another forum that I use, and thought I might as well post on a few other forums incase anyone wanted.
