ThePlatinumShadow
Hi Guys,
Been using my current build for a few years and have had a number of issues around heat and unstable performance on both my 1100T and my HD6990 (Chosen at a time when I knew very little about what I was actually putting in the case).
The issues have gotten worse over time and now I'm starting the research and costing stage of my next build so any advice would be hugely appreciated. I'm currently looking at an AIO but I'm going to be looking to build a custom loop as a phase 2 project once the build is operational.
My current thoughts are at:
http://au.pcpartpicker.com/user/Veritas/saved/3nsnTW
As for the questionnaire:
I'm based in Aus and am working to a budget of no more than AUD$4,000.
I currently have a G15, Razor Mamba and 3 1080p BenQ monitors that I've been running in Eyefinity at 1080*5760.
I will be needing a new OS as I'm going to repurpose the old one as part of a server build.
Primary use is gaming however CS (Photoshop, Illustrator, Premiere, After Effects) will get enough of a use that they are definitely a factor.
I do intend on overclocking and this is going to be a clean new build.
Any feedback regarding choices or suggestions would be greatly appreciated.
