from what i read he is using 2x of them 1 60mm and 1 80mm,
As to what rads are good, alphacool have some nice rads, UT60 for 60mm and the monsta for 80mm tho 2x of the UT60 would be perfectly fine for what your wanting to cool, and i personally dont see the 50% extra cost of the Monsta warranting the little bit extra performance as you arent realy pushing the limits of 2x 240mm rads as it is. What case are you using by the way?
The case i am thinking of using is Nanoxia Deep Silence with the two rad , the reason i was thinking of the 240 by 60 and 240 by 80mm thick rads i was going to water cool the motherboard as well because it need to be silence. i have to sleep about 5 foot from it and it is on 24/7 at the min and it is like a jet engine at the min not cool
Sorry TTL for the post earlier English is bad sorry
From what ive seen that case would only fit a 45mm rad in the roof possibly only a 30mm?? (i think tom did a video review where he walked around every part of the case in detail but dont quote me on that)
Also do you know if you can you get water blocks for your motherboard?
