Freeview TV Card
Hyper
Hello All
I am totally new to the TV card world but fancy one and my dad says he will buy me one as the freeview box i got for my birthday is now down stairs
Any recommendations would be helpful as i dont have a clue about the advantages and disadvantages of one from another.
Thanks, Sam
i cant recommend a nebula tv card enough. ive had mine for about 10 months now.
Quality = 10/10
Software = 10/10
and there are still making improvements to there software. It works with topup tv too (although you have to buy a adapter to plug the card in)
it also looks like there going to be making the software HDTV complient when they start the trials this year,
for more info, go here > http://www.nebula-electronics.com/
nath
As I have read the bext card is the ATi TV Wonder Elite which I have, I haven't used it since I got it but its the best one out right now. I also have a Hauppauge PVR-500MCE which is outstanding with dual tuners.
I'm stuck with a Pinnacle analogue capture card. What are the chances of Sky ever allowing anyone to produce a compatible capture card?
name='kempez815' said:
I can record sky on my Hauppage card :)
Yes, but that's still analogue. Don't DVB cards record the direct digital stream? only way to get Sky is to decode and re-encode.
o and at the time i brought my nebula, it was the only card that just ripped the ts stream. resulting in better quality.
I am quite happy with my Compro DVB-T300. It has analog and digital input, cable for power on. The Windows driver/software are updated regularly.
Works like a charm in my Linux Mythtv box.
