Fractal R3 Build 470
neoguyver1
Intel® Core™ i7-930 Processor
Noctua NH-D14 CPU dual fan cooler
Gainward GeForce GTX470
Zalman VF3000F
SAPPHIRE Pure Black X58 PB-CI7S41X58 - Motherboard - ATX
Kingston 3X2GB HyperX Blue 1600MHZ
Fractal Design Define R3 ATX Tower + 3 Fractal fans
PSU: 600w jean tech fully modular sli
SAMSUNG HD502IJ
Windows 7 Home premium 64
Various scores and speeds used below usually above 4ghz and 850mhz core on 470.
http://www.youtube.com/watch?v=JFhj6X5d7fI&feature=youtu.be
yea looks good indeed, only thing I'd have to say is maybe a new PSU "Jeantech" mmm is a bit iffy... well this is completely personal opinion by the way. I just had a few things from them die pretty fast, and currently using one of there cases the Jeantech aqua. its terrible and small tight as a tiger you could say. other then that yea you got some nice kit there
lol yea i robbed it out of a family members i am planning to get a better branded but she seems to be holding up.
Yea is quiet i actually branched the 470 heatsink with the CPU fans with a 3 way splitter as i didn't want to fiddle about with the fan mate and seems to work well together.
The cpu socket is a little high on the sapphire and i had to remove the top modu vents to get clip on the 140mm fan.
Using nvidia inspector for the overclocks having trouble working out some of the nvidia flashing software. The zalman cooler does come with an impressive heatskink for ram and vrm's etc is a pity the fans aren't 4 pin as i bought an gelid adapter but it needs the 4th wire to control it.
I am playing skyrim on max so happy enough with it is for sale like the last one i just love building.
Noob question even though i disable the power saving and stepping and so on in Bios, the voltage i pref does not show as you will see above, what is the setting for voltage to stay ant the specified voltage selected?
My old gigabyte seemed to do this no prob am i missing something?
Have a video with fans running check it out.
