tolagarf
Member
Hey guys.
So I'm considering a little project of mine, a secondary PC with simple and cheap liquid cooling adding on a water block for the GPU. Hence I thought of the Fractal S36 (or S24).
Has anyone done this so far? What was your experience with this in regards to performance and pump noise etc.
Also in the manual it's states that if one is to switch out the original fittings/adapters, it has to be G1/4" DIN thread. Wth is DIN? Is it the same as BSP? I'm just slightly confused on this. Fractal also states in the manual that if using other fittings than the original, it should be from either Alphacool or Phobia and some third company which I don't remember. Are Bitspowers and EK fittings out of the question then?
The reason I would want to switch out the original fittings, is because they're not exactly easy to find ones that would match, and the tubing is a weird size, as not very common (8mm ID/11mm OD).
