Fractal Design Kelvin T12, S24 & S36 pumps?
The_Governour
I am wondering if the pump of the T12, S24 & S36 are the same?
I have heard that they are not very strong pumps, but would they do to push through a waterblock + gpu and maybe small res?
I am looking at the T12 version of this AIO.
T12 being the smallest version? You would need atleast a 240mm rad for both CPU and GPU, else you risk running those units too hot. If you're looking for an expandable AIO, you're much better off with a Swiftech H220-X/240-X imo.
No, it is not possible to use the H220/X with the setup that i have in mind, also I know that to water cool a GPU and CPU on one 120 rad is pushing it but it will have very little OC. If the ship a 295x with 1 single 120mm rad and its *ok*.....
Still, is the Fractal pump good enough?
I don't really know regarding this to give you an answer and this isn't really helping... but have you tried to contact Fractal Design directly and ask if it is powerful/good enough?...
I sent them a message but the damn Swedes dont respond! ;) Also any fractal products must be dirt cheap in Sweden!
I sent them a message but the damn Swede´s dont respond! ;) Also any fractal products must be dirt cheap in Sweden!
Haha... well I can't respond on their behalf, but some Swedes are like that unfortunately :p
Well.... depends on which store you buy them from to be honest and which product it is.
Some can even be quite to get hold off, luckily I have a store which I've gotten to know 2 people that have a higher position so they can usually place an order for me on a specific product :p
What product were you referring to? :)
The Fractal Kelvin T12 or the S24 are the highest on my list, but If I could buy JUST the pump top then that would be the best.
