Fractal: Deadpool
Craigferrie
Fractal DeadPool
Teaser Video
https://www.youtube.com/watch?v=icA0g9F9rRY
Welcome to project: Deadpool
This project is based on the ever famous deadpool comic character above.
First of all, Huge thanks to fractal Design and TTL for selecting me as 1 of your 5 modders for the competition.
And a huge thanks to
for jumping in the boat and sending me out some awesome Blitz series RAM for the build.
I'm not good with renders so don't blame me when it doesn't turn out exactly like the render. I'll get some done this weekend.
Here are the renders of what it will look similar too, no guarantee's it'll turn out identical to these
So, let's take a look at what were working with
Fractal Define S - Case
**What's going to happen to the case**
First thing is first, i've ordered some red and black leather.
This will be used to cover the entier case (alike deadpools suit)
Strange that i'm using leather huh ? :P
two slits will be cut out of the top back of the case, and two samurai swords placed through them as if the case is a sword holder
Inside the case, there will be a custom made power supply cover made in jet black, with the word "FRACTAL" cut out and then the same word in red placed in.
This will be backlit so the name fractal glows
Fractal also sent out their Kelvin S24 Cooler
**What's going to happen to the cooler**
First of all the block will be re-sprayed a nice deep red and then the radiator matching
i was going to change the tubing, but no need to ruin the cooler.
Fractal also included 2 pretty nice 120mm VENTURI fans
**I'll repray these to match the build**
All together now
Finally, here's a run down on components. (Pictures will follow once i've decided)
Confirmed parts
Avexir Core DDR4 Red RAM
Dark power pro 11 1000w 80+ Platinum
i7 6700k
red/black braided cables
ASUS ROG VIII Hero
ASUS Strix 980Ti
Corsair SP red fans
Unconfirmed parts
i want to use LED lit fans for this build, fractal don't make them, so i'm forced to go with another company for them
Here's a quick look at machine with the products
Yes there is cardboard holding up that Strix 980Ti.. Thing is far too tail heavy.
One of thing i always add to my case mods is this little fan extension box, it's a serious life saver.
Soo. that's where i'm at so far
Will update as things progress.
Progress day #2
Quite a bit has changed here's a quick rundown
1. Motherboard tray has been wrapped in red vinyl
2. Fans changed over to red LED fans.
3. PCIE Slot covers changed over to red.
4. SSD Mounted to the back tray
5. White LED's fitted to bring out the red
Update: Changed out the corsair fans.
now using Fractal Venturi HP fans
Re-sprayed red
Updates
Front panel:
Started by cutting the correct size sheet of 3mm Acrylic
Drilling holes to screw the facia onto the case
Drilled out the rivets on the top and bottom of the case
Drilled out the holes for the fan and radiator.
Fan deadpool's for the centre of the fans
Deadpool thin black for the window and 1 large deadpool dome for the front of the case.
This is where i'm at tonight 01/11/15
Update
Will get some HD photo's this weekend. Here's a look at DeadPool tonight.
Update, Avexir Blitz RAM arrived for the Build.
Here's some Shots of the RAM.
So it's now the 7th of December (Dead line for this contest)
Here is the final shots of Fractal: DeadPool
nice dude, i look forward to seeing where this goes :)
EDIT: also really liking what you done with the cpu block :)
Haha, i just wanted to throw in some more ROG while deciding on what MB and GPU to use. Will decide tomorrow if i'm going with gigabyte or ASUS.
CPU block is just a sticker, not done any painting as of yet :)
let me guess Gigabyte GA-Z170X-GAMING 7?
if only i have the money for skylake, that would be the mobo i would be going for if the review is good....
i'm not entirely sure myself, if i had the cash... G1 all the way. I'll see tomorrow whats on sale and whats not.
love this case, will get it for christmas :)
You really should!
I honestly don't know why i never bought this case, ended up with the phanteks pro M, the Define S craps all over the Pro M in so many ways.
The only thing that could make it a better case is a power supply cover/Shroud One of the first thing i'm making for this case :)
day 2: Little update
Need to clean down the red as it's covered in greasy finger prints that make it look awful.
Nice! Love what you did with the red panel. Neat ssd placement too
very nice dude! liking the panel vinyl wrapping you done there.
Thanks, was far easier to wrap the back panel than paint, especially when i only want the back panel in red.
As for the exterior, no wrapping there. leather sheets should be here tomorrow (fingers crossed) sewing machine job. Also the acrylic sheets are due any day now too to make the fan grills and PSU Shroud
Wrapping (Much safer option for people looking to do minor mods without causing damage)
I've got a large roll of red (Purchased from ebay for £2.00 and an art scalpel knife which is only a few quid also.
Once the size needed was cut out, i removed all the motherboard raisers and simplayed lay'd the vinyl onto the motherboard tray (Remember to ease out those air bubbles)
I also got my drill out using a size 3 drillbit, marked 2 dots where i needed to drill to mount my SSD (1 hole in each corner top and bottom) Make sure if your doing this to only use a size 3 drillbit as any bigger and your SSD will move around.
How it looks now that i've tidy'd it up
Removed all the greasy finger prints
You'll also notice i changed out the PCIE Slot covers to red ones. you can pick up packs of 5 online (ebay) for around £3.00
PSU is upside down
*edit*
With that much red in there you are going to need some white LED's to help it pop
i fell for that once before, not gonna happen again lol. Although the be quiet! PSU does look far better ''Upside down''
I've literally just tried using red cold cathodes and it glares too much.
thanks for the tip, i'll order in some white :)
Always white dude,I used to go with coloured cathodes and leant from my mistakes. I only use white leds now the give a more natural glow and accentuate the hardware.
Thanks, yeah i see some strips on ebay going really cheap, will do the job just fine!
While waiting for the plastics to arrive here's a rough idea of the PSU Shroud i'll be making
Looking good dude.
Silly question, will the Fractal writing be visible? Looking at my case it looks like the window is pretty high up.
Looking good dude.
Thanks.
no, it would be hidden by the frame of the window panel.
I am considering using a misty acrylic sheet as a window, just one whole sheet, screw it on to the frame.
All comes down to how much funds i have left.
