So here we are, ready to put the system together for the first time. First things first a quick update on what's changed/arrived since the last update. Firstly I manged to trade my old 1TB drive and a bit of teaching for a 3TB 3.5" drive; game storage is not going to be coming up short any time soon.
When I installed the new HDD I actually decided to unhook the power cable from one of the clips running around the case. This has released the tension on the cable and has made installation of the cage a whole lot easier.
I've also received my motherboard and RAM alongside a new slim fan for the AIO and some high quality thermal paste.
Opening up the motherboard box you're presented with a familiar sight; an anti-sttic bag with your new component inside. Once that's out you can see what else has been included.
The manual is well written, however any experienced builder won't need it. I only found myself checking it for confirmation of the front I/O connections. Also included is the obligatory I/O shield alongside the Bluetooth/Wi-Fi antennae and a pair of SATA data cables. I immediately popped the I/O shield in place.
Next I opened up the processor and installed it. Nothing unusual here, just a standard LGA 1150 socket and CPU.
Now time for the 16GB of Corsair low profile RAM. Again, nothing particularly exciting here. They are solid pieces as you'd expect from Corsair.
I couldn't help but get goosebumps at this point. My next stage was to dismantle my current rig for some of the last components, but being a family man I decided to make time for my wife before removing the only source of TV she has. While waiting for her I found myself sitting at the table just smiling and looking at all the details. Even being a fairly simple motherboard without the fancy aesthetics of higher end gaming boards I find Gigabyte's offering here no less exciting; maybe that's just the geek in me coming out as I haven't done this for five years.
Anyway, an hour of MasterChef later and I'm pulling my old system apart. I'll be re-using my PowerColor Radeon HD 7870 GPU, Antec Kuhler 620 AIO CPU Cooler and 128GB Samsung 840 Pro SSD boot drive.
My old system was on the AMD AM3+ socket so the next job is to get all the fittings for the AIO off the old bracket and onto the Intel one. This was exceptionally easy and after ten minutes of trial and error I had the new bracket set up for the correct socket (I had set it up to big to start). Mounting the AIO itself is simple; back plate on the underside of the board, a pea sized blob of Thermal Grizzly Kryonaut and screw the water block on.
I find it ironic that this was one of the things me and my friend who built my first system really struggled to do; in many ways this was the easiest part of this build. To mount the motherboard in the case I found myself having to remove the PSU and HDD again, which was frustrating but not unexpected. The Silverstone FTZ01 manual does specify to mount the motherboard first. I guess I was just too excited to be finally building a few weeks ago that I just
had to do something.
PSU and HDD now back in place (for the third time) it's time to start thinking about cable management, starting with those AIO hoses. Nothing a pair of zip-ties can't handle.
This is where things really started getting difficult. The cables supplied with the Corsair power supply are very, very stiff. Combine that with the overhang from the 3.5" HDD and getting everything plugged in became an arduous slog of trial and error. The cable are also clearly designed with a traditional tower layout in mind; there's no way you could have two 2.5" HDD's, a 3.5" HDD and an optical drive powered with just the supplied SATA power cable. Although it has enough ports it simply wouldn't route correctly. I'll be purchasing some extension cables for future updates to make this a little easier to handle. I'd also recommend that if you're going to be using a 3.5" drive in a case like this then plug the cables into the PSU first.
After finally getting the motherboard fully powered I got the fans hooked up. The 15mm thick Prolimatech fan is a required item if you want to use an AIO in this case. It's a squeeze with a fan that thin so a full 25mm is out of the question. Thankfully Silverstone provided pass through screws to mount 15mm fans to radiators as a the Y-splitter which let me plug both GPU bay fans into the one spare header on the motherboard. The only problem I really had was that the Antec Kuhler supplies power to its radiator fan through a 3-Pin female plug. A quick hacksaw job to remove one edge of the plug and the PWM Prolimatech fan plugged straight in. Even better was that I could route the cables in the fan frame behind the mounting screws ensuring the cables followed the hoses back to the motherboard.
Mounting the GPU and SSD onto the GPU bracket was extremely easy.
Working out where to run the power cables was not however. I ended up remounting the GPU three times with different cable routing before resigning them to simply run between the GPU and case fans. I really hope Corsair offer some softer, more pliable Type-4 cables in future.
It was late by this point. It'd passed midnight and I was keen to get the build rounded off. In my haste I grabbed the orange and red SATA cables from my old build instead of the nice new black ones Gigabyte had provided and got that storage drives hooked up. With the radiator mounted on the lid it was time to see if I had broken anything expensive.
The good news is that it started. Without messing around in the BIOS it gets confused when starting up and requires a bit of intervention to get into Windows, but I did manage to get Fallout 4 running and the improvement was immediately noticeable. Frame rates are solid and I even managed to bump my graphics settings up despite no change in GPU.
I promised my wife I'd make the living room presentable again before heading to bed so I packed up all the odds and ends and put the computer in its proposed new home.
First job for tonight; get into the BIOS and set it up correctly. Then I'll jury rig my current optical drive into the system to install Vista, then the Windows 7 update. From there it'll be a free upgrade to Windows 10 and then a fresh install of Windows 10 itself from my home-made USB.
My next purchase will be a BD drive for the system and some peripherals. After that it'll be a new screen and GPU; maybe a 1TB SSD at some point too, for newer games.
Thanks for taking the time to read this. I know this build isn't all that exciting compared to the masterpieces that are presented here, but I've enjoyed documenting the build and look forward to continuing as I upgrade more components.
