Flex
Socks
Hey guys, been looking for about an hour now, gone through all my trusted sites etc and still no luck.
Im looking for that Uchannel flex stuff to chuck around the edges iv just butchered using my new diamond dremel bit. Anyone know a few good sites to look at for this?
Cheers :D
Are you going to mount a window? There is stuff that has two channels so that you can put it over the metal and the window and it holds the window in without screws or the like.
Edit: Just saw your second post after I had posted.
I found the WCUK stuff cheers guys. Would love to know where that other stuff is, the double channeled stuff for holding window and locking onto the edge...anyone know where to find it??
