First WC project
CoolFish
I am about to order my first attempt for water cooling. Going to fit it in a Fractal Arc Midi.
XSPC 240x60mm rad in roof
Laing DDC1+ Ultra Pump 600 L/hr with XSPC Reservoir Top (Bundle Deal)
Watercool Heatkiller LC Rev 3.0 CPU Waterblock for Intel 2011, 1366 : Copper Acetal
What fittings and tubing should I use?
Is the pump/res good enough to install a second rad and gpu block?
Also can I buy I side window panel for the Arc Midi?
Thx
Fish
your missing alot of parts mate lol plus you have 2 pumps and rez's
EDIT lol changed it with out re-posting lol fittings and tubing are alot of personal preference I like the way Tom does it without clamps so i use 1/2 barbed fittings with 7/16 tubing makes a super clean look without the added cost of buying compression fittings I do like the look of the compression fittings just the added cost I dont want to pay lol. I would think that pump could handle 2 240mm rads and dual blocks. easy enough.
