walsingham100
From what i have read on these and other forums and you tube vids I think i am on the right road with this but i wanted to run it by you guys just to make sure.
Switch 810 case
rx360 rad in top
rx240 rad in bottom
xspc bayres with 2 x d5 pumps in series (overkill or good for redundancy?)
http://www.overclockers.co.uk/showproduct.php?prodid=WC-163-XS&groupid=962&catid=2141&subcat=
raystorm cpu block
2 x watercool gpx blocks foor 7970 cards
Fans will be just push, probably corsair sp120 quiets
tubing/fittings to tase
I guess i would go pumps/res -> cpu ->360 rad -> 2xgpu blocks ->240 rad ->pump/res
What you guys think? especially with the dual d5. I guess I want some proterction in case the first pump fails.
cheers
Switch 810 case
rx360 rad in top
rx240 rad in bottom
raystorm cpu block
cheers
