Elderbree TM
Hello every body :wavey:
_________________________________________
this here will be my first beast of a rig(mind you i had and have pretty good rigs in the past and present but non was W/C or OCed ) so you will have to bare with me and with alot of semi to outright stupid questions(
so without further ado lets begin
First, Time Frame
well I'm contemplating on waiting for the MoBo until mid to late September as there is supposed to be the new X38 chipset ready by then and hopefully it will support SLI so....(if you think its wrong to do so please advise)
so I'll start ordering stuff that are not MoBo dependent(as in :can go on mosts MoBos out there) and once i decide on one I'll get the rest
Things i already have
6x Raptors (4x150 GB and 2x37 GB)(but I'll probably only use the 150 ones)
3x Assorted 250GB HDD
1x 24" Monitor (but I'm looking to buy a 30" [maby an HP LP3065]
looking for recommendations)
1x Sound Card X-Fi Elite Pro
8500x green papery things you use to buy things with in the states
I'll edit this post every time i get a new component
Things i need
first of all i can always use more of the green papers mentioned before
1x Digi Camera to take pics of the process and posts them here (advice is required as i know nothing of Photo shooting)
1x ENERMAX Galaxy EGX1000EWLScratch that i just read thy withheld a prize thy promised so i will be looking for a different PSU
1x 8800 Ultra GPU (should i go ASUS on this or is there a better option out there?)
2x sets of OCZ DDR3 PC3-12800 FlexXLC Edition
the rest will be edited in as i get recommendations
so here it is guys(both Male and Female) the ball is in your court now
and do remember I'm a bit of a :noobsign: here so...
First, Time Frame
Things i need
