First build
Robotdinosaur
I want to build a rig that will play games around 60fps at 1080p at a budget of £800, now the GTX660ti is out i would like to base my system around it. I also want to SLI 2 660ti's in the future. Here is my parts list:
Cpu: i5 3570k
Motherboard: MSI Z77 GD65
Graphics card: MSI GTX 660ti power edition OC
Ram: 8GB corsair LP vengeance
Case: Fractal design R4
Power Supply: Enermax NAXN 850w (I'm not sure if this is enough for SLI)
I need a decent CPU cooler for about £20 and i'm not sure which too buy, I already have some hard drives.
Please tell me if i should change some parts or if this will suffice, Thank you^_^
500th post! Yay! :D
OT: 650w would be enough, though I would suggest a 750w PSU. Just for some headroom for overclocking. The HX750 or the AX750 from corsair will suffice :)
i had a Fractal design R3 and the airflow wan't great and ended up going for a switch 810 after watching tom's review and never looked back. you can do so much with the switch 810 it's unreal also a lot cheaper now like £120 OR NZXT Phantom at amazon for £83.
Perhaps get yourself a CoolerMaster Hyper 212 EVO cooler, works well and should allow you to get a pretty decent overclock on that 3570K :)
Guys, this is a 4 month old thread and the OPs profile says that his last activity was 2 months ago.
It's nice that you try to help him, but this is probably not going to help anyone :rolleyes:
