First build
jesse525
It took me awhile to get this done, but I have my first home build thought I'd show it off. It has a ME4 for the Motherboard Intel I7- 2600K 2x4GB Mushkin Frostbyte Redline a single EVGA Nvidia 570HD for GPU the cooler is an Noutua NH-C12P SE14 a single SSD for the OS and everyday programs and two mechanical HHD for one for game's and mics. storage powering this set up is a Corsair AX850 all put together nicely in a NZXT Phantom which isn't the easiest case to work with mind you, I'm having a hard time cleaning up the cables for the hard drive bay. outside view.jpg
Well done on your first build, looks good.
the phantom is almost too easy to work with... the cable management on it is pretty good sure the case will fall apart within the year but it has some decent features
I'm already looking for a new case one of the LED on the my fan control is already not lighten up.
I agree it is easy to work with. I'm just stumped on how to neaten up the hard drive bays, it probably such a simple way to do it I'm not noticing it.
Nice rig you got there! Gotta love the C12P, I've had one myself for a long time.. Just recently got the D14
Looking for a new case? Have you checked out the Silverstone RV02? Maybe RV03, but I haven't read too much about it, don't like the looks of it..
The C12P looks epic in the RV02, it cools really good in it as well.. And the GPU's temps will probably drop a bit as well
If you want LED's in a RV02, the best choice is cold cathodes, not really alot of place to switch stock fans for LED ones
Heres a pic of my rig when I had the C12P, PICTURE
Welcome jesse525, can't wait to see cable management updates. I can see a few small things that add up to a big difference.
Nice setup. The Leds on the fan controller only light up if they have fans plugged into each separate section, had the same problem with my mates
