Firefox Button
Finlay
Hallo,
I often use Firefox, a great browser, and sometimes go to Tools - Options - Security - saved password to read and erase the passwords for the sites that I visit.
Do you know if there is a way to shorten this path, maybe insert something in the toolbar to speed up this task?
Thank you
I have no idea, I assume it would be possible with a bit of clever editing of the files.
One thing I would be concerned is, what if you accidentally clicked it, would be annoying to loose all your passwords and have to re enter them.
You can just press Ctrl+Shift+Delete uncheck everything except "Active Logins" and delete passwords.
You can also set the time range as well.
The problem is that I have to delete a single password at a time and not all.
Thanks the same.
Bye
