Final i7 Build
I was looking at the Be Quiet range am going to look at some reviews check re the O/C potential.
Should have everything by Friday and am starting my build then
Can't wait!!!
there is no dught that the NH-D14 is the best air cooler but if you were leaning towards a be quiet one then they would do the job just as well because the 2nd gen i7 doesn't need as much voltage to get to a high clock and it doesn't get nearly as hot as the 1366 i7's get to, either the dark rock pro or dark rock advanced would probebly performe just as well.
http://www.aria.co.uk/Products/Comp...ark+Rock+Advanced+CPU+Cooler+?productId=43590
http://www.aria.co.uk/Products/Comp...Rock+Pro+Dual+Fan+CPU+Cooler+?productId=43588
both are cheaper than the D14 and in my opinion look alot better.
D14 wipes the floor with Dark Rock and friends
