few pics of my watercooled rig!
Warlord Shigs
heres pics of my rig
specs:
danger den lga 775 tdx blok
danger den intel chipset block
danger den maze 4 actel block
single heatercore
double heatercore
hydor l-20 pump
ehiem 1250 pump
specs:
single heatercore
double heatercore
hydor l-20 pump
ehiem 1250 pump
I don't see any pics ?
Nice setup Shigs, good job you've done there, squeezing all those bits in that case. What res are you using there? and are you using any kind of relay switches with those pumps?
Cashman said:
No res that I can see... I can spy a T-Line tho ;)
Why two pumps tho shiggshie?
2 help with the flow rate, and yeh ur right mate no res jus a t-line ;)
this really is a great case if u jus cba 2 do alot of moddin :D
If the pumps arent the same, and so balanced in terms of flow rate, arent you limited by the smaller pump, meaning that it could be worse to run 2 pumps, with the extra heat it puts in as well as the extra tubing?
G
G
G
yeh im aware of this now mate, i need 2 get another 1250 pump, dnt really mind as i need 2 change my waterblock 2 amd64 anyways :D
I've got one not being used at the moment, like new :)
PM me if you're interested.
