Feser X changer rads
Over rated personly. Paying for the box and bits in there. Least there got a decent paint Job. Thermochill is still lacking big time despite many mails to Marcus about it
:confused::confused::confused:
Me?
EDIT: Oh wait, do you mean Marci? :rolleyes:
I'm another huge Black ice Fan. Mabey not as 'good' as TC or TFC, but I;ve never had any issues, and the chrome one make me a little happy in my pants.
will be trying a 480cm soon will let you now,I'll tell you this much woudl have had a thermochill if they did a 480cm but I suspect rad for rad theres little in it, but they look well built and come with screws, however they are expensive
As promised heres my 2 cents using a 480cm and a 240cm on my cards, and I must day they are very nice rads...well built, comes with all screws for mountung, rubber fan shrous nd a handy bleed screw gettign the air outa the loop is considerably easier temps around 43C idle and 63 prime small FFT's and this is on a 480cm detek fusion V2 and xilence profans @12v My cpu is clocked at 1.41v and 4.05GHZ
They are good rads, and do come with a decent package (*curses the fact Thermochill dont use normal threads/screws*), but compared to the likes of Swiftech and XSPC they are overpriced.
If pure performance a 480 X-Changer is the way to go, but generally a PA120.3 or BI GT-Xtreme would do just as good a job.
God.. 480cm? 4.8m?.. now that's a RADIATOR!! .. I understand what you mean though and couldn't resist..
Anyways, You've got the black ice radiators which are awsome.. Asetek use them, innovatek uses them.. Don't get tube radiators like Airplex EVO series from aqua-computer, they work, but not as good as the propper ones.. The Pro and XT series from aqua-computer though are also EXCELENT rads..
If not you've got koolance.com who also have good radiators, and 4x120mm ones.
-Bubba
