Following on from my thread about having problems with downgrading the BIOS on my P5K i want your opinion on a few things that have happened lately.
Basically, i started off with the 0902 bios and had my Q6600 clocked at 3.4ghz stable (12 hours prime, no errors or warnings). I then upgraded to the 1009 (?) BIOS and couldn't get it stable even at 3.2ghz. So i eventually managed to downgrade to 0902 again, i have now got my Q6600 stable at 3.2ghz (14 hours in prime, no errors or warnnings) but it won't last past 1 minute in Everest no matter how many volts i put through it if i go any higher. Aswell as this i have had a couple of other things happen.
1) Every so often i get the "Overclock failed" screen with i boot the computer, but it if i restart it willl boot fine (remember, 14 hours in prime, no errors or warnings) and run fine.
2) A couple of days ago i turned the computer on, it go to the full screen logo screen, went blank as it does when it switches to the next screen, then restarted and carried on doing this in a loop until i turned it off.
Is it worth me taking the mobo out and RMA'ing it, or has changing the BIOS just lowered the clocking capablities of it?
Other components are:
Q6600
4GB Crucial Balistix Tacer 1066mhz
Seagate Barracuda 7200.11 250GB
HIS Radeon 3870X2
The Q6600 is watercooled and loads temps are ~49C.
Q6600
HIS Radeon 3870X2
