W warro158 New member May 1, 2012 #1 HIIII, just wondering if anyone can tell me of a low noise high air-flow, blue LED 120mm fan? thanks
PetrolHead247 New member May 1, 2012 #3 Bitfenix Spectre's are a great choice, but it all depends on what exactly the fans are going to be used for
mundivalur New member May 1, 2012 #6 Looks good Xigmatek Crystal 120x120x25mm Blue LED Case Fan : CLF-F1251 Air Flow : 61 CFM Speed: 1500rpm Noise: 20.0 dBA Dimensions: 120x120x25mm http://specialtech.co.uk/spshop/cus...m-Blue-LED-Case-Fan--CLF-F1251-pid-11508.html I have Yate witch are good also ! Yate Loon 120 x 120 x 25mm Case Fan Transparent with Red LEDs 1350 RPM : D12SL-12+4LEDR Air Flow : 46.0 CFM Speed: 1350rpm Noise: 23.0 dBA Dimensions: 120 x 120 x 25mm
