fan's for 140mm x 3 rad
lemonpledge
spectre pro is moderate in the static, look into the BGears 140 @ 3.5mm/h2o. awesome for
performance, can be undervolted without major loss of air-flow, double ball-bearing, and for low dollars spent.
i have them in my midi waiting for the 280 front rad mod.
airdeano
I'm using spectre pro's on low and have no issues what so ever. great fans and quiet as well
The BGears look good .. static pressure is almost 6x over the spectres and I plan on having a fan controller so at 50% rpm they'll be at 1.75 mm H2O and 18 Dba ... so whats the down side of these puppies ??
really none.. cost is sub $15USD
undervolted to 7-volt there are no complaints in mech noise, air noise is much better than 12-volt
and @ .5m no noticable noise.. just watching the blades spin..
airdeano
look at the spectre PRO'S not plain Spectre's while the BGears are 6times the plains there just over twice the PRO'S in static pressure but the BGears are about 14db louder than the pro's
Ty for the heads up sin ....they must be popular as most of them are currently out of stock ... good feed back on them as well . So far I think I'm still leaning towards the gears as I'm half deaf from the trades anyways :)
