Fan speed help
Dario_92
I have a fan controller that I have my 3x120mm radiator fans hooked up to, I plan on getting rid of my fan controller as it is a PITA. What can I use instead to keep the fans quiet ? I was thinking about the NZXT fan Grid but wasn't sure if it will make the fans run at 12v which would be louder than what I have my fans running at (900rpm currently). I was also thinking about buying a fan splitter and just running a 7v reducer and plugging them into the motherboard ?
If you have any ideas as to what I could do it would be much appreciated :beer:
Thanks, Dario.
