Faaip De Oiad
I am in the process of modding an old steel case that I intend to make a silent pc out of. I have cut 2 fan holes in the front for intakes, a ceiling fan and two rears for exhaust. All 5 holes are 80mm.
I have also applied Akasa sound proofing kit to both the inside of the case and also inbetween the steel/plastic wall on the case's exterior shell.
My question is this:
Will I be able to run non-silent fans in my case silently due to my sound proofing material? Or should I just buy fans rated as silent just to be sure?
(i.e. will loud fans be made quiter due to this material?)
Also, can anyone recommend any fans in particular? I do not want LED fans, just plain old black ones
Thanks for the help guys.
What do you think of this? http://www.zalman.co.kr/eng/product/view.asp?idx=30&code=016 It's going for only 3.50 on a competitor's website.
I also realise that running slower fans will adversly effect my maximum overclock, especially on my smoking hot 3.2Ghz prescott, but by how much? Will I be able to get decent temps at all with 5 silent fans and an insulated steel case??
(FYI: I am currently using a Mach II GT prommy, so this is going to be very strange for me not having temps of -40C lol)
