Just go to your online shop of choice and search for fan controllers, there should be a bunch which are made to be hidden in your case and have 7 or more fan headers, they don't have a whole lot of differences, so any will do.
Do you need one for 4 pin PWM ? if so you might struggle with a fan controller, a lot of PWM fans don't like fan controllers and the fans make an awful humming sound that is louder than the fans.
You'll probably be better off getting either an Aquaero 5/6 or just voltage drop cables. I've git the same problem with having all PWM fans and have tried 2 different controllers and both have had the same effect. That's not only on the fans I use but I bought 3 other fans to be sure and they all hummed.
