Fallout 76 now supports Unlocked Framerates on PC
Ahhhh so that is why it was happening !
lol this will get better by the day now. Time I get around to playing it it should all be working :D
Bethesda never mentioned it because it's not implemented client side properly yet, the game still runs at 60fps, if you want unlimited frames you will have to edit the perfs.ini.
Same as before then. Hopefully it won't break terminals and etc.
It didn't before the patch so long as you didn't try running ultra wide resolutions or customperf.ini files, of all the forums I've visited either pre or post BETA including the fallout 76 sub reddit those complaining the most are those who are trying to mod files like it's a boggo FO4 or Skyrim game.
Just seeing lack of widescreen support is a "no deal" for me.
Every Fallout game has been the same. The logic is not to buy anything in the PC game that is not universally supported. I'm not having a dig (because I've spunked thousands down the drain on tech that was never even used properly) but that's just how it is.
Since buying my boggo standard 32" 1440p I have had 0 issues with anything.
