F1 2015 system requirements announced
WYP
News Guru
F1 2015 system requirements have been announced, with the minimum GPU requirements Including Intel GPUs. Well that is rare.
Read more on F1 2015's system requirements here.
WTF? A 970?!? Are they f***ing crazy? I remember that I could play F1 2014 on fullHD with my iGPU's HD 4600 graphics with med settings. Now they want a 970, which I have, but I do not now a car game that requires so much power. Only NFS games come closer, but I can perfectly run Rivals with my current system on 1080p.
Hahahhahahahahahahahaha
First time I see the Intel graphics beeing included in the Recommended specs. Also the FX 9370 beeing the recommended cpu
"New Engine".... it's the same EGO 3.0/4.0 engine they used for Dirt Rally, which is just the spit & polished Dirt 3 EGO 2.0 engine with new physics and shaders bolted on. Adding a number to an existing Engine does not make it "new", as for the system requirements, blah! It'll run exactly the same as the previous games. Now unless they have dramatically increased the poly count of all the models since 2014, *cough* I doubt it, simply due to console hardware restrictions nothing will be different other than lighting and shaders.
PCARS is very demanding when maxed out even with no AA.
Looks like they misunderstood what "recommended specs" means. It looks like they're going "If you want to run this maxed out with at least 100 fps; this is what your system should look like."
Exactly and the 5th Gen intel graphics can do just that :rollinglaugh:
