Extra load on a PSU???
PV5150
G'day Guys
Just wondering if anyone knows whether extending your PSU looms, would add extra strain to the PSU itself. To make things a little clearer, what I have decided to do is mod my case in preparation for H2O. I want to completely hide all wiring, by either ducting it through channelling pop rivetted to the chasis or under a false floor (necessity is the mother of all invention). An extra...say 300-500mm's on some of the shorter looms wouldn't cause too much of a load would it?
Feedback muchly appreciated
PV :)
no mate..ir wouldnt really...it wouldnt cause half as much resistance and modular plugs would so u shd be ok
You'd be adding extra resistance at each additional plug u used which isn't specifically a great thing but if you're smart about it you should be able to get away with it w/o affecting your PSU's performance.
Each additional plug used on a single line/cable creates the same amount of resistance as if you added 2-3 extra feet of wire, just keep that in mind :)
name='Dave' said:
nick i like ur new sig and all......but its spelt 'signature'..not 'signiature'
I wasn't going to say anything... :p Why couldnt u have just left him be lookin' like an ass, hehe.
