TheKeyboardDemon
I'm thinking about getting this cooler, I want to use it on an AMD Phenom II X4 965BE and an Asus Crosshair V Formula mobo with Corsair Vengence ram but I can't find a good video review and some of the web reviews I've read are not helping me to decide as the results seem to vary.
I want to overclock my 965BE and have found that when I get it to 3.91ghz I have stability issues using my current cooler (Corsair H50) and the error codes point to thermal issues so I'm looking for something that will do a better job of cooling my CPU. Prime95 Torture tests get my core temps up to 62 degrees and sometimes higher with that overclock so I have had to reduce the oc level for the time being. I also use Corsair Vengence so I don't want to have to change my RAM.
Would this cooler be a good choice for me?
I think the balck cooler and red fan would fit really well with my black and red mobo + GPU colour scheme but I don't want to buy a cooler just for the looks if it doesn't perform.
Any help would be appreciated. Thanks.
