I do like their dual fan however which is on the SC editions. Would have been even better on the SC is they they had made the cooling vanes annodized black
Either way, their new twin fan look is far better than their previous generations, so they are on to a good thing. Outstanding clocks too.
All the talk of how it looks but in 90% of PC's all that will be seen is the backplate, just a thought it would be better if the fans and the nice looking part faced upwards when in a case
I know the ribbon's are available which is why I said in 90%, obviously alot of that 90% will also be stuck under or beside a desk so it wouldn't make a difference, it was just something I had pop in my head a couple of times when looking at GPU's and boring backplates
True - or you could use a mirror/mirrored finish on the PSU shroud if you have one.
The inverted cases may be a good fix but they're pretty rare. I'm looking in mine now and I can see the wrong side of my SoundBlaster X-Fi, and the two backplates for my GPUs. None of the good stuff!!
I imagine it's because heat rises so in a typical scenario you want the fans blowing the air over the heatsink and then up and out the back fan. Bloody thermodynamics ruining my aesthetic
