WYP
News Guru
EVGA GTX 1080 Superclocked edition has been pictured with EVGA's new ACX 3.0 cooler design.
Read more on EVGA's GTX 1080 Superclocked.
I can only imagine how amazing the Classy is going to look![]()
Id like to see a vendor put out a card with no cooler whatsoever for watercooling. Save money on not having a cooler so that you can fit whatever waterblock you desire.
That's actually a cracking idea and I would be all over that
It's actually a pretty silly idea from a marketing department point of view. They'd have to deal with all the parents who bought their kids the cheapest 1080 they could find not knowing that it's cheaper because it's unuseable out of the box unless you have a watercooling loop which is something a pretty small subset of the already small subset of GPU buyers that crave the high-end segment want.
Better to put out a version with the cheapest possible cooling solution, basically just a radiator and fan so the card can at least be used out of the box.
Your basically saying all parents are morons who don't read product descriptions!
You advertise a card as pcb only no cooler and you show an image of just the pcb no cooler I'm sure even the thickest of people could work that one out.
Small subset???????????????
Right ok so watercooling UK, EK, Aquatubing, XSPC, Bitspower, Alphacool and the huge number of WATER COOLING companies are all supported and make a profit from a small subset??
word.
not that the coolers matter to me in the first place as im all about the water cooling. im interested in whats underneath the fan and radiator. and what is annoying about that is that if i want the best guts sometimes oyu have to pay for the best cooler and strobing rgb leds. id rather get the best guts and save 30 pounds on a card that has only guts and no pretty shroud so i can add what i want to add . if a person has a budget and they are determined to sli then if each cooler costs a hypothetical 30 quid thats a saving of 60 which could mean the difference between a set of corsair vengeance and a set of dominator platinums. i know this is a silly point as its part of the risk when watercooling or even simply applying superior thermal material but if you dont have to disassemble the card and only add the block then that is 50 percent less work you have to do handling the thing and therefore 50 percent less time to do something stupid and wreck the thing and reassemble it as original for a false warranty claim (loljk). and while i under stand what you are saying elo i would like to think that if a parent was spending 600 pounds on a graphics card that they would either be knowledgeable about what they needed to buy or the child had previously informed them.
its like the difference between buying a road worthy car and buying a rolling shell of a car for you to add your own engine of choice. the person with the cash should know whether or not the car runs or requires an engine.
