i usually love EVGA products. And they get points for trying. But GOD it looks bad
But IMO a quick disconnect system are not going to look awesome, as all hoses are at a fixed length = Its a NO-GO in a case with a windowed side panel. And if it's not visible, then why buy the bends
lmao yep. I hadn't thought about him for months but I did yesterday as soon as I saw that. That is a face only a mother could love tbh. God knows what they were thinking.
EVGA could have launched a range of pre filled tubing of various lengths with a quick disconnect at each end which would have attached to the components.
The best way of shortening tubing is to have it the right size in the first place.
Now that is a better idea, though it must be remembered that the tubing routing clips are not set to ever be released. They are just a concept product.
The only problem with your idea is the need for a huge number fo quick disconnects, the cost of which will quickly add up. Then there is the size of the quick-disconnects to consider, as they are pretty big ATM. That being said I still like your idea from a user perspective, just not sure how it would be executed well ATM.
