EPUK Mav Cracks 11k in 3dM06
The guys I have seen scoring like that have an FX60 running at over 3.5ghz, knowing that if I had one that would run that speed (RIP my beauty :() then the scores would be closer to 12k.
The FX60 I have now is capable of 3.2ghz @ 1.55v so watercooled it's a beaut, but the cold bug prevents serious clocks under phase.
Roll on 0550 or 0602 stepping Fx60 ;)
Well done mav great score in a tough bench mark!!
Have you got any tips and tricks to add to the sticky?
There are no tips for this right now - purely because rivatuner is not 7600/7900 series compatable.
Therefore you have to either modify the clocks and delta via the GPU BIOS (which I did) or use something like powerstrip to up the clocks in windows and rely on the sheer horsepower of the card to get you a better score.
Cards are benching at 700Mhz GPU (35mhz DELTA) and 1800Mhz (900mhz x2) memory right now....... which is nice :)
