The Sensor test is showing Core 0 Sensor Movement 0 and Core 1 Sensor Movement 3.
This processor is under a D-Tek Fuzion block and I don't have much experience watercooling Intel CPUs but I was getting lower temps on air with my old AMD.
Quick go with the Asus overclocking tool heralds 3.6Ghz with all settings on auto and a 1:1 with the memory. The program decided I needed 1.32V and with Prime95 running RealTemp reports 46 degrees - not too bad I suppose.
One question though, my RAM is rated 1000Mhz; do you think it would be possible to retain a 1:1 ratio and increase the FSB whilst remaining within the boundaries of the CPU voltage range AND keep it stable?
