WYP
News Guru
The Dying Light PC recommended specs have been released. 16GB of ram and a R9 290 anyone?
Read more on the Dying Light's PC requirements here.
16GB ??? sorry but that's just ludicrous, This stinks of unoptimised garbage.
I applaud any development house who's willing to actually push the limits of current hardware. However, I hope this isn't the case of yet more unoptimised code being hyped as a positive thing due to its system requirements.
We've had a few titles of late that have seen some ridiculous "recommended" spec requirements yet, a couple of patches (or 3rd party mod/tweak) later and they're looking just as good on lesser kit, while holding a respectable frame rate.
If it genuinely needs the reported specs to give a fluid, 60fps experience at a given resolution then that's fine. If I don't meet the requirements, I'm happy to turn down a few settings to get the 60fps experience I want. However, if I see both my CPU and GPU under-utilised yet still get poor performance I'd not be pleased. Equally if I was constantly hitting my vRam cap yet the textures looked average at best I'd be equally annoyed.
I really hope these are genuine specs because the game has pushed fidelity that little bit higher than main-stream can handle.
Btw: I'd imagine the 16gb system ram figure just facilitates shorter load times / area transitions / item pop etc. I welcome anything that actually uses ram smartly if it's available. Would I be right in saying that 16gb is considered the norm for anyone building a gaming system these days? Running 24gb myself, but that was because of another project I was playing with some time back.
Scoob.
Is it really 16GB RAM or is it 8?... as on here it says 16, but on the link below is says 8?...
http://www.pcgamer.com/dying-light-system-requirements-are-killer/
Here are the real system requirements, Which Techland sent over to me via email this morning.
Minimum:
OS: Windows® 7 64-bit / Windows® 8 64-bit / Windows® 8.1 64-bit
Processor: Intel® Core™ i5-2500 @3.3 GHz / AMD FX-8320 @3.5 GHz
Memory: 4 GB RAM DDR3
Hard Drive: 40 GB available space
Graphics: NVIDIA® GeForce® GTX 560 / AMD Radeon™ HD 6870 (1GB VRAM)
Direct X®: Version 11
Sound: DirectX® compatible
Recommended:
Processor: Intel® Core™ i5-4670K @3.4 GHz / AMD FX-8350 @4.0 GHz
Memory: 8 GB RAM DDR3
Graphics: NVIDIA® GeForce® GTX 780 / AMD Radeon™ R9 290 (2GB VRAM)
Direct X: Version 11
Techland also included these "additional notes":
Laptop versions of graphics cards may work but are NOT officially supported.2
Windows-compatible keyboard, mouse, optional controller (Xbox 360 Controller for Windows recommended)
