Dust filter?
NyanCat
Hi, I will be getting dust filters for my 120mm fans but had a question- which is better from Silverstone, the, FF123B or the FF122. What is the difference between the two exactly? Thanks!
looks to me the ff123b has a finer filter in it....the more open design looks like it would make up for the slightly lower airflow dew to the finer filter? but i could be wrong on that lol. both should work fine. the 123b tho would catch finer (smaller) dust.
I have both of them and they have the same mesh.
The only difference is look. So pick up that one that look better for you.
