Duronic DM653 Triple Monitor Stand - Any Good?
Reviews are pretty good. Only supports up to 22" though..
If you look at the 4th picture (their whole range spec sheet) it shows max is 27" so think that should be more than enough! SPS have you seen anything else you could recommend?
Only says 22". Looks like the table is wrong.
I've only had bad experiences with triple monitor stands. They are very hit and miss.
I'd be looking at something like this. Reviews seem to be ok, and looks solid enough on the base. Still though - I couldn't guarantee it would be perfect or anything.
http://www.scan.co.uk/products/scan...-monitors-with-height-tilt-swivel-rotate-vesa
Seems to be a lot of conflicting information as their website states up to 27" (http://www.duronic.com/Duronic-Mount-Monitor-Bracket-Swivel/dp/B00DG6CLDY).
Just a bit off-putting.
So would you recommend buying 3 single stands over 1 triple stand in that case?
XFX's triple monitor stand is expensive but from experience it seems to be up to the job.
It only really supports 3 24' monitors but its solid.
That looks pretty solid though I was kind of hoping for something that would give me more desk space. Would you recommend staying away from desk clamps considering the recommendations here have all been stands?
I used the OCUK one which has a reasonably large stand and it was absolutely terrible. The stand was well under standards required to support three 23" monitors. The XFX looks like the sure fire way to get a suitable stand, it's just the cost.
The XFX stand looks like it's taking up more desk space than 3 normal monitor stands combined, so unless you're buying one because your screen's stock stand doesn't offer hight adjustment and so on, I don't really see the the point of that one
I have bitten the bullet and gone for the single mount version of the original one I posted. That way I can suss out the quality and see if its any good. Hopefully will be able to report back soon.
In the case of the Dell stands it's nowhere near.
Duronic DM651x2
Stand arrived. First impressions were it was pretty well built. A couple of plastic pieces could have been better quality controlled but a very minor point.
Had no issues mounting my 24" LG 1080p monitor and clamping to my Ikea desk.
The only critical thing I would say is there is a plastic friction twist piece underneath to secure the height of the arm. This is not really strong enough and I used the provided screw into the pole to give better grip.
Interesting. Keep us posted on how the quality holds up after some time. I'm always interested in a good quality monitor stand.
