Dumping Physical Memory
chownsy
Help My Computer Keeps Dumping Physical Memory, I Dont Know Why It Does It, I Have It Randomly Do It When Playing Games And Aslo When I Click Shut Down It Does It Also.
It Comes Up Codes To Do With Bug Fixes
Help Help Help Help Help
My Rig Is As Follows
Amd Athlon 64 X2 2mb Cache 939 Socket
400gb Sata Hdd
Asus Ati Crossfire Ready Mobo
2 X Dvdrw
2gb Ddr400 Pc3200 Ocz Platinum
Watercooling With 3 Radiators And A P6 Pump Including Northbridge Cooling
Windows Xp Home Edition
I Have Loads Game Installed, External Dvd Drive, Webcam. Usb Joystick Installed
Any Suggestions Welcome
Thanks In Advance
Richard Chowns
If you don't have a Floppy drive you can also use a flash drive with integrated floppy drive emulation.
As long as your motherboard supports booting from a USB port... ;)
I found it really useful!
What games are you running?
For example, Dark Messiah and Oblivion are notorious for causing memory probs. Dark Messiah suffers badly from memory leaks and Oblivion is so resource intensive, I find it takes ages to quit back to Windows, and during shut down the hard drive goes crazy while the swap file is cleaned up.
BATTLEFIELD 2142, CSS, COMMAND AND CONQUER GENERALS, CALL OF DUTY 2
name='Kempez' said:
Or you can make a boot CD
Also worth checking you system forstability with Orthos or something
you got a link to that software, i will need to make a boot cd because not got a floppy drive or a flash drive either.
cod 2 is renowned to give this
too
too
the game that made it crash was cnc generals, cod2 crashed to desktop (ctd) only, bf2142 ctd alot. css is sweet but hardly play it
Have you checked event viewer in Admin Tools. Sometimes it'll pinpoint which component is the culprit, maybe a .dll file within the games folders or something.
in the event viewer i cant find the error code that i had for the crash.
there are alot of error codes for something called DCOM
Still Crashing
Hi All Again
I Thought The Problem Had Sorted Itself Out But Today When Listening To Music It Crashed And Dumped Physical Memory. Can You Tell Me How To See If My Ram Is Stable. And If It Is Not How To Fix This Problem
Please Please Please
Thank You Very Much
name='Kempez' said:
MemTest86+, Orthos Blend Test
What do I do, where do i download these from and how do i run these, do i have to make a boot cd and run them from that or run them via windows.
name='Kempez' said:
Google it mate
And yes the Memtest86+ needs a boot CD, but Orthos is a Windows app
Please stop shouting
i didnt mean to shout, i didnt realise it had caps on till i posted it. memtest or orthos, which is easiest to use or is it best to run both.
http://www.memtest.org
which 1 at the bottom do i download, bootable iso or bootable binary.
also how do i create a boot cd with NERO thank you
