So here is the question, up to now I have been switching the secondary psu using a relay, the one I have been using is a standard 4 pin relay as used in the motor industry nothing special,
The pull coil on this item has a resistance of 80 ohms and when energized it uses 160 milliamps, this was driven by a molex connection to the primary psu (relay terminal 85 and 86) to switch pin 4 (green wire) to ground pin 6 (black wire) on the secondary psu (relay pins 87 and 30) to switch it.
I am currently using a Corsair AX 1200 pro, this being single rail, I am somewhat anxious about using the relay, so at this time I am switching the secondary PSU manually each time I start up.
Is it possible that a constant 160 milliamp load on one of the periferal rails is harmfull, and is it ok to hook a single and dual rail psu together.
any input greatly appreciated
Cheers all
Rick
Cheers all
Rick
