H hackalive New member Mar 2, 2013 #1 So I have a dual CPU board and going to use Xeon E5 family CPUs. Now I know I need them to have the same stepping, but do they also need to be from the same batch? Obviously you can't get the same serial number. Cheers in advance.
tinytomlogan The Guvnor Staff member Mar 2, 2013 #2 As long as they are the same type thats all you need ie: two of e5-2687
B NEGATIVE New member Mar 2, 2013 #3 tinytomlogan said: As long as they are the same type thats all you need ie: two of e5-2687 Click to expand... +1. Same type is all thats required.
H hackalive New member Mar 4, 2013 #4 okay so step, batch etc are of no relevance as long as they are the same model e.g., E5-2687W
KING_OF_SAND New member Mar 4, 2013 #5 hackalive said: okay so step, batch etc are of no relevance as long as they are the same model e.g., E5-2687W Click to expand... That is correct.
