Dual core motherboard
Jego
Hello, I wanner make a change to my Computer. Acer (-.-) Aspire e500-zb72
So im gonna buy these parts:
Grfx. Nvidia Geforce 8800 Gt
Cpu: Intel C2D Q6600
And 1k ram.
But one of my freinds says i might see if my Motherboard suports Dual core.. so i open Cpuz to try find out, and i just cant find anything on the internet about it.
Motherboard:
Manufactor: Acer (-.-)
Model: Erc410m
Bios: Amarican Megatrands Inc.
Version r02-a0
Hope you guys can support me!
Say if there smore info you need, will try find it then
Which CPU is currently in the computer? There's a good chance that it will not support any of the new C2D processors if it's running an older LGA Pentium 4.
Googling for the model you gave came up with:
http://www.ngohq.com/members/big-adr.html
In the profile info he has the same mobo and a "Pentium 4 524" cpu, checking here:
http://fr.wikipedia.org/wiki/Pentium_4
I see that cpu is socket LGA775, which is the correct socket for a C2D... the only question is whether the motherboard bios supports the newer chips.
I think this is the model of PC you have:
http://global.acer.com/products/desktop/apf5.htm
It says "The latest Intel® processors feature dual-core technology for heavy-duty multitasking" but that might not mean you can run C2D. I wonder if emailing them would help...
It's possible you may need A BIOS upgrade to allow the newer chips:
http://support.acer-euro.com/drivers/desktop/power_F5.html#bios
Ive curently got an Celeron (!!!) 3.06 ghz (Cpu-z)
And thanks for the link... i think ill try call them today
My guess is that your computer is not compatible with C2D processors. It more than likely uses an older/less expensive chipset that does not support the new chips.
Hmm its tricky.
Direct question: Is it easy to change motherboard.. i coud i right as good buy a new computer?
If you decide to buy a new PC then if you have the time and inclination I would suggest building your own. If you haven't done it before then once you get some basic advice it's not all that hard and it can be great fun and quite rewarding. All you have to do is take it slow, and ask whenever you're unsure.
You also get the best parts for your money and you know exactly what you're getting and can make choices which will allow an easier/cheaper/better upgrade path in the future i.e. by picking a motherboard with a cpu socket which should be supported for longer, allowing you to upgrade just the cpu for example.
If you want advice on what to get this forum is a great place to ask for advice, just give us a budget and some idea what the main purpose for the machine is ie. is it a gaming rig, if so what games do you want to play and at what detail level (med? high? full?) or is it perhaps a media pc, or maybe you're a graphic designer or record music or ...
Ok look what acer just send me about my Motherboard:
Dear K.Jacob Thank you for your question,
Q : Hello Acer, i woud like to ask you about your Pc E500-ZB72 its aboutthe motherboard... Can it drive an Dual core cpu. Bouth the computer withan Celeron. Hope you guys can help me out here!
A : Your Pc Chipset :: ATI RC410 Express chipset + ULI M1573 CPUsupport.. Socket Type : Intel Socket T.. Supports Intel Pentium D FSB 800MHZ.. Supports Intel Pentium 4 Prescott 775 / FSB 533/800MHz.. Supports Intel Celeron Prescott 775 / FSB 533MHz.. Pentium 4 2.66GHz ~3.8GHz speed.. Celeron D2.80GHz ~ 3.06GHz.. L2 Cache varies with CPU from 1MB to 2MB (for 6xx series CPU)
If have any question,please call to 02-6854355 (Technical Line) or sent toE-Mail
As I suspected your chipset doesn't support Core 2's. I'd look at just building a new computer from the ground up using some of the bits from your current computer such as the HD's and optical drives, etc.
Yep, i guees ill have to go buy a new motherboard, grfx, cpu , ram
the Price shoud be at 500-600 euro highest.... Im living in denmark so the prices are a little higher here and we are counting Dkr 1 euro = 7,5 dkr
My Target is World of Warcraft and Jedi knights jedi academy..
My fps in WoW is 15-20 I want it to go up to 50+
Ok guys... gona steal my dads cpu tomorrow.. its a pentium 4 he dont use that old computer anymore and some ram... hopefully it will boost me enough to wait a half year to make my new computer.
