Hi, im thinking of getting a new GPU. Now I'm not an expert, so i would like to ask: Would the MSI GTX 970 4G Gaming fit into my Xigmatek Asgard III Case with the Z68 extreme3gen3 Motherboard?
Thanks in advance!
It will probably fit as long as you have no hard drive installed at the same height as the video card (I couldn't find how long of a GPU the case actually supports).
Either way; I'd stay definitely recommend you to upgrade your case to something with a little more room, and definitely more airflow.
