So, I am trying to flush out my reservoirs, but I am having a problem with my approach, and I wouldn't mind some input.
I have my pump and res together, and attached to my rad - it should pump water into the rad and flush it out. I have the out port of the rad dumping into a temporary container. In this container is section of tubing with a filter at the inlet; this tube is attached to the in port on the res.
The problem is that no water is returning to the res from the temporary container; all the fluid in the res is pushed into the rad and not replaced. Does the D5 pump create a suction in the res, or is the inlet in the res just supposed to receive fluid that is "pushed" into it?
Images below may further explain what I am trying to do.
