do compressor coolants need to be recharged now and then?
Refrigerant will be fine in a system as long as you have no leaks or the compressor burns out if either of these happen you will need to replace the refrigerant
someone mentioned that the coolant gets absorbed by the oil overtime?
does this happen in these danfoss compressors?
Yea, I think that happens whenever the compressor is off... I`m DEFINATELY no expert, but I think they separate when the comressor is turned on and the pressure is building up. But please dont hold me to that. Theres a good chance I`m wrong.
