GuppyFishNoob
Hey guys im currently in the middle of a DIY watercooling project for my PC. After searching on eBay i managed to find a mercedes benz radiator for 5 bucks so i am using this as the rad for the CPU loop im hooking up. this may sound stupid but will this radiator be able to dissipate the heat from my CPU passively? Thanks for any help guys
CPU:
i5 3570K
4.0 Ghz
Stock Volts
Radiator Dimensions:
420mm wide
615mm long
46mm thick
CPU:
i5 3570K
4.0 Ghz
Stock Volts
420mm wide
615mm long
46mm thick
