Distilled water on the high street?
ZeroInfinity94
Hello people,
I need distilled water for some cleaning of my loop.
But I cannot find it anywhere on the high street.
So two questions.......
Is De-ionised water alright to be used to flush out a block, rad, res and pump?
If not where the hell can you buy distilled water thats isn't online?
Thanks.
Hello people,
Thanks.
Overclockers sells it. Pharmacy might have it too, like boots.
Distilled is easy enough to buy, our B&Q sells it as does our local tool station. You can use De-Ionised if you want just be sure to add some biocide into the mix, the only difference between the two is that De-Ionised water has only had the metals removed and not the bio organics which would otherwise be removed via the heat phase of a distilling process.
