display
khanage
hi all new to the forum.
im in the process of modding a case at the mo and have a mach2gt but my display is yellow/orange an im after a blue one.
i did buy a screen and solder the plug to it the same way as i removed it from the origianal but when i connected it up there was nothing so i reversed it an it just lit up with no writing so i re-soldered the old one an it works fine so im guessing i need a certain type of screen.
so the question is where can i get a replacement screen,i looked through the manual an it says there avalible in blue but i can't find where to buy one.
thanks dave
My advice to you would be to keep an eye on the classifieds in this forum, maybe post a "Wanted - Mach II display in blue" thread. Aha, you cannot - you need to have a post count of 50 or greater before the Classifieds section will be available to you. Maybe somebody could do that for you?...? You could try eBay, just this last week there have been 2 Mach II displays for sale, the sellers username was/is xskit. The other option would be to buy/import one from an online merchant.
Here, I have found one, the price is very good although the P&P will cripple you!
http://www.frozencpu.com/products/1260/cas-334/Prometeia_LCD_Kit_-_BLUE_9274B.html?tl=g41c207s435
Oh and welcome to the forum!
thanks for the reply man.
looked on e-bay an managed to get a white one for £25,not the blue i was after but looks more blue than white so im happy:D
im hopefully gonna be fitting the water loop an phase this weekend so will post up some pics when its done,theres still gonna be a fair bit left to do before i can call me project finished but it should still look cool.
u can check the project log out at OverclockerZforum.com
