Dicehunter
Resident Newb
Latest version of DDU has just been released.
Changelog:
- Additional AMD CleanUP based on Cat 15.7 under Windows 10
- Small fixes.
- Translation Updates: Turkish and Chinese
Download Here
AH there is actually a newer version now.. just checked. 15.4
I know but it's not really worth posting it as there have been no functionality changes only translation changes to Korean and Spanish ^_^
And yes it supports Windows 10 bud![]()
Cheers Dice I will be swapping Motherboards and shiz tomorrow you naw what i mean innit blud
you nutteri'm changing out my AMD for the Z-97 which I got from TTL plus THE LOANER PENTIUM K
I know the feeling buddy I had a very long lunch with the Mrs and her Father![]()
I'm so sorry, You deserve a pint after that !!!!
*EDIT*
Scratch that, Thought it said mother, Father in laws are cool, It's the mothers that can drive you crackers ^_^
Being a Father myself one thing you learn is don't get involved![]()
I was wondering if you (Dice) use DDU in safe mode or in standard windows? I've used it in both and was wondering if I'd be better off just sticking to safe mode.
I use DDU in safe mode as it's the best way to make sure there are no errors.
